Nationwide database submissions
wbswetnam
DMR-istan
How does someone submit an update for the nationwide database? "Nationwide" does not appear as an option under the "State" drop-down menu. I am wanting to submit tone data for the Red Cross (146.2 Hz).
INDY72
Indianapolis, IN
In a way you just did. Which freqs?
Sent from my LG-K330 using Tapatalk
INDY72
Indianapolis, IN
On low band they pretty much do and the high band they use is the national sar freq usually
wbswetnam
DMR-istan
From the posts I have seen reference to relief efforts for Hurricane Harvey, 146.2 Hz was reported. Also, about ten days ago I heard a Red Cross convoy coming through Arkansas on its way to Florida, I think, and their PL was 146.2 Hz on 47.420 MHz. So, I venture to say that that is their tone for nationwide assignments.
ecps92
Taxachusetts
Exactly, I've seen, depending on the Region many different CTCSS tone, no one common tone across the country has been found.
Are you sure that everywhere in the country uses the same tone?
