Ncc (not Receiving)
mandlair
Hi,All 396 isnt picking up ncc again try all the control channels with the stars?maybe my antenna? thanks Mike
DELCOLHFC
S.E. PA
Check all of your settings, maybe something got locked out accidently or a mode setting was changed. I have 868.2125 between 70-99% decode on my Pro-96 right now.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yeah Mike if you're programming CC only you have to have ALL of the control channels - the reds and blues - otherwise, as you've discovered, one day the system shifts to a CC you don't have and you loose trunking. Of course if they use a different CC we don't have in the db, then you have no choice but to check all the frequencies to see which one they are using 73s Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The only way to find the missing cc, I think, is to plug in all the other freqs and hunt. The sound is unmistakable; unless you had a 'senior moment' and locked out a cc by mistake? That is a definite 'DUH!' moment, hi 73s and good hunting Mike
baydog
Severna Park.MD
If the NCC system is part of the statewide Delaware system, check your system type setting. I was not receiving anything for Sussex Co. when I learned from another posting that the system type should be set to Motorolla Type 2, not Project 25 . Once I made this change, the Delware system magically came to life.
David
mandlair
Hi, all I have everything set right.It comes and goes I guess my question should have been did they switch control channels.They have in the past ......But I put all of them in and still spotty at best.Oh well maybe the weather or time of year.Thanks Mike
