NCSHP 800Mhz Frequencies
K4ASJ
Mount Olive NC
Hi ! I Was Wondering If There Were Any 800Mhz Frequencies For Wayne,Sampson Or Johnston Counties.
Thanks To All That Replies
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
Even the typo errors - and incorrect info - are identical.
With regards to 800 MHz, Andrew, there is a query for the FCC database that will allow you to specify state, county and frequency range ... and the query then provides the licenses fitting the query.
Go to: http://svartifoss2.fcc.gov/reports/st_cty_freqrange.cfm
Enter "NC" for the state ... then the county you want to look at ... then the frequency range. The frequency range would typically be 851.0125 through 868.9875 (or a segment of that). Remember to enter an "M" before the frequencies you enter.
For service code, leave the setting to "all services," unless you want a particular service.
Choose ULS licensing on the next page.
Any licenses that come back with a two-letter service code starting with a "Y" are trunked licenses, and any starting with a "G" are conventional.
The database was not working this morning (Sunday) ... the FCC occasionally has parts of the database down for maintenance ? during weekend hours. You might have to wait until Monday to run your queries.
Jeff
