Need a stronger antenna
rane
Hutchinson, Kansas
Hello, I own a Whistler WS1040 digital handheld scanner and my reception isn't good now that I have moved to a different area. Any recommendations on an antenna that will not break the bank but help with reception?
Whiskey3JMC
Just another pesky scannist
Simulcastylvania, TE
Please post specific examples from the database on what you're having trouble bringing in & where you've monitoring from if not Hutchinson, Kansas so we can make an informed recommendation for you. The antenna might not be the issue
rane
Hutchinson, Kansas
I am in Hutchinson, Ks and the pic attached shows the band I think.
Whiskey3JMC
Right off the bat your county sheriff dispatch is fully encrypted...
DECHEXModeAlpha TagDescriptionTag
236693eDEReno Co SheriffSheriff DispatchLaw Dispatch
Though their ops channels are listed as clear (this may or may not be accurate) :unsure:
2369941DReno Co SO Ops 1Sheriff Ops 1Law Tac
2370942DReno Co SO Ops 2Sheriff Ops 2Law Tac
2371943DReno Co SO Ops 3Sheriff Ops 3Law Tac
2372944DReno Co SO Ops 4Sheriff Ops 4Law Tac
If you're still in Hutchinson your police dispatch is fully encrypted as well so that's a no-go
236793fDEHutchinson PDPolice DispatchLaw Dispatch
Their tac channels are listed as clear...
2400960DHutchinson PDTacPolice TacticalLaw Tac
2401961DHutchinson PDCarPolice Car to CarLaw Tac
2402962DHutchisn PDSurvlPolice SurveillanceLaw Tac
Any other talkgroup ID'ed as mode "DE" is fully encrypted meaning it cannot be monitored, peroid. You'll only be able to pick up talkgroups ID'ed as mode "D". Both towers on KSICS listed as Reno County are single-site so this rules out simulcast distortion. If you're looking for an antenna improvement over stock then you should consider the Remtronix 800-B. However if you have any cell towers in your immediate area this could hamper your reception of the 800mhz band
rane
Hutchinson, Kansas
Right off the bat your county sheriff is fully encrypted so you can cross them off the list
Ok, well I do get sheriff channel, ambulance and fire. The dispatcher conversations cuts out frequently. I will try the Remtronix and thankyou for your suggestions.
