Need advice programming split freq simplex
LoveMoto
I am trying to program a channel with split frequencies such as 461.075 for TX and 466.075 for RX. I have tried it with Talkaround enabled and disabled but i cannot get the raido to transmit, I assume the split freq configuration makes the radio search for the repeater and when there is not one it disables TX? I get the same tone as if Channel Busy, but the channel is not busy. Please share any tips for getting the radio to TX thanks
What kind of radio
Yeah, that would help...
You should be able to program in your TX frequency and your RX frequency however you want. Unlike some ham gear, it won't force you to specific band plans. If it's giving you a tone, that sounds like you have something set that you shouldn't, like MDC looking for a repeater, or you are trying to program out of band.
Details would be helpful.
emacs
New York
A DMR channel will wait for an ack from the repeater before allowing you to transmit with different TX/RX freqs. A hacky way around it would be to program a simplex channel with the TX freq and assign a scan list with the RX freq, but obviously not an ideal solution.
