Please excuse my ignorance, To me it seems like it hasn't been that long ago when replacing crystals was the way to change frequencies. I purchased a older but new scanner RS Pro-163, I know this is going to be one of those 'Oh no, not again threads.) I've searched read and re-read the trunking programing until I'm confused. I'm trying to program Albertville Police and Fire frequencies (Alabama).Albertville Police & Fire Trunking System, Albertville, Alabama - Scanner Frequencies Before long my home town Arab PD/FD is going to MotoTRBO system and the reason I wanted/needed new scanner. I can get to #5 and this is what confuses me. my scanner LED reads
P101FM 0.00000
PRI DLY lo +
Bank 1 Chan 01
Bank 1
What is the actual frequency I put in? These 853.30000c 854.83750c 855.88750c 856.76250c, or something else, Or am I doing this wrong?
P.S. What is the c that is on the end of the frequencies?
To program a Bank for TRUNKING:
1. Press PROG, then press TRUNK.
2. Press FUNC, then use an UP or DOWN ARROW to select a bank.
3. Repeatedly press MODE to select a trunking mode (Motorola).
4. Press PROG.
5. Enter the first control channel freq. and press ENTER.
6. Repeatedly press MODE to select a trunking mode (Motorola).
7. Press PROG or the UP ARROW to advance to the next channel.
8. Enter the next control channel freq. and press ENTER.
9. Repeatedly press MODE to select a trunking mode (Motorola).
10. After the last control channel freq., press ENTER, then press SCAN.
Now you should start to see all active Talk Group IDs (TGs).
P101FM 0.00000
PRI DLY lo +
Bank 1 Chan 01
Bank 1
4. Press PROG.
