Hello everyone!
I have been using IC-F4001 for a few years now. I had a local dealer who programmed them at first, but he closed his business a while ago.
2 years ago I ordered a few more IC-F4001 from the US (I am in Canada), along with a OPC-478 cable (rs-232, not usb).
I have been successfully using the programming software CS-F3000 1.1 at that time and I easily cloned them.
I just ordered 4 new transceivers (same ones, IC-F4001) and received them last week. Somehow, it is just not working, I am unable to read or program them. I've been trying anything I could think of, I've read all what I could find on forums. I tested my old transceivers and it is not working either (but it was working in 2014...) I don't get it... What am I doing wrong? Why was it working before and not now?
If anyone could give me a hint, I'd be so grateful!! I am not very familiar with programming, but I generally can reach my aim with a bit of work
Here are the details:
- transceiver model: IC-F4001
- programming software CS-F3000 1.1
- cable: OPC-478 (rs-232, not usb)
- OS: Windows 7
When I try to read the transceiver, I get this error message:
"No answer from transceiver. Check the following:
-The COM port settings.
-Cloning cable connections.
-Transceiver power is on."
-My transceiver is definitely on.
-I don't see what could be wrong with the cloning cable, it looks in perfect condition, it is clean and it has been working in the past.
- As for the COM port, I have tried all the ports which were listed in "device manager"(1-3-4-10-11-12-13-14-15-16-20-21-22). I get the same error message for all of them. (I don't see however that any of them says "icom" in device manager)
-I tried both normal speed and high speed with all these ports, same error message...)
Am I supposed to download a driver? (Icom driver seems to be only for usb OPC-478)?
Thank you in advance for your help! I'd love to be able to use the new transceivers
HTF
- OS: Windows 7
HTF
