I am very impressed with my new PSR500, but the only thing I am having a problem tracking is the GO transit P25 system
Does anyone know the LO channel, HI channel, base, spacing and offset
for this system to input into the custom table? I am using PSR edit and having some trouble with this one. It is a Motorola UHF-lo system using P25 9600 baud
Do I input this into the trunking table as a "P25 manual" system or "VHF/UHF"
I am thinking 12.5 spacing but not sure what to use as base freq. (380mhz or 406mhz??)
but not sure on the other parameters...
I searched in the message archive for scanont and RR forums and found the parameters
that some were apparently using for their PRO96's when the GO system
came online but I've had no luck with them thusfar.
BTW I am in Courtice and I can see on the PSR500's control system
analyzer function that the control channel is coming in at 95%. on 410.0625
Transmitter site is up the road at Mitchells Corners tower site. I am monitoring activity
by programming channels in conventionally but cannot track...
Here's the RRdB link for the GO transit system in Ontario.
http://www.radioreference.com/modules.php?name=RR&sid=4579
Any help would be appreciated
Glen
in Courtice, Ontario Canada
Glen
