Need help with Kenwood TKR-850 programming.
ramal121
Lots and lots of watts
Calif Whine Country
When it resets after programming, I have to turn off the red button before it will send the DQT and open the walkie.
So when the repeater fires up this button is active and you have to turn it off? Make sure this function is not assigned anywhere else especially at Optional Features>Other>Startup or to anything on that page. Also check the Function Port table. Both those will parallel a physical button push.
garretcanter
Yes. I have to assign it to a front panel key. (Then I have to get up and turn off - make it where it is no longer red) I assigned it to the "Start Up" under the "Others" tab and it still does not cause it to function.
The Function Port table does not appear to have anything assigned.
The only thing that works is to assign a key and turn it off after start up.
I don't want this in case the power flickers.
Also, the CW ID never seems to work - even in Start Up - and even if the "Yes" is on and CW ID is on Start Up
kd4efm
EL98 Florida
Any chance you can email me your codeplug, because the tkr850 I tested with does DPL without any interactions.
kd4efm1 at gmail dot com
