Are you using software? It's much easier if you use one of the software packages available. Most of them have a free 30 day trial period. The programming is the same for the RS PSR106/197 and the GRE PSR500/600. You will need the programming cable USB Scanner Programming Cable - RadioShack.com to interface the scanner to the computer.
Im using win 500...followed step by step....loaded the feg...everything programmed fine.....then i push scan on the radio and its not scanning or picking up anything.
Attached is a zipped copy of my PSR 600 WIN500 file for eastern Idaho. It won't help you for Boise, except it will show you how I have everything programmed. Maybe it will help to compare with your programming.
