Need help with walkie talkie
K4EET
Chaplain
Severn, Maryland, USA
I am using it for my farm.
If you are in the United States, you are potentially using those radios illegally. I don’t want you to get in trouble but ignorance of the law is not an excuse. You may also interfere with another radio system that could result in loss of life. Many farm operators use GMRS radios. Have you considered GMRS for your needs?
K4EET
Chaplain
What? 😱
What are the rules?
no but I will look into it!
The rules are specified in the Code of Federal Regulations but depend on what you are doing (business, personal pleasure, etc.) which is further regulated by radio service and frequency used.
As for GMRS, you can read about that here:
RadioBoy2025
My walkie talkies has FCC ID does that mean it’s legal?
K4EET
Chaplain
Hmmm… Stand by @RadioBoy2025. I cannot get the app to decode that number. Let me ask the group here…
I am getting a “Federal Shutdown” page that I can’t get past. Is everyone else seeing that? I wanted to decode that FCC ID to see what Parts the radio is approved for.
Those are FRS radios, which are legal for you to use in the USA without an FCC issued license. Don't go by the info on the Amazon page, it does not jive with the manufacturer specs.
As for them not working together, that is ~usually~ a setting mismatch between the radios.
The owners manual is available here:
Go through the settings and confirm that:
All radios are on the same channel.
All radios have the same CTCSS code set, if used
-or-
All radios have the same DCS code set, if used
There's not much more to these radios that would keep them from talking together.
The only other possibility is that one or more of them is damaged. That's a real possibility as these are a lower tier Chinese product and quality is not high. They are not repairable.
If you follow the above steps and still can't get them to work, toss them and get some new FRS radios.
RadioBoy2025
-or-
All radios ahve the same DCS code set, if used
Ok thanks!
K9KLC
Southwest, IL
Less ten feet but I also tried like hundred feet and had no luck.
I'd skip the less than 10 feet testing. At 100 I'd think they'd work however. I guess you have bum radios is all I can come up with. If they were working then suddenly stopped not much more to do. Had they never worked together that would be different but if they. worked before and just stopped I'd ship em back and get something different.
K9KLC
Southwest, IL
@mmckenna posted a link to the manual, go through those radio settings and make sure they're all identical. I agree with the above, I know you said they were working and stopped but it still sounds like a miss match in settings to me.
RadioBoy2025
Ok!
Should I take a video of what is happening?
K9KLC
Southwest, IL
Ok!
I don't know what a video will help but I guess it couldn't hurt either. I mean they're either talking to each other or not. As I posted above I'd go thru the manual, and double check all the settings. According to the manual, it follows many FRS radios channel convention so a lot of different radios would actually work with them. (assuming the manual is correct). the thing I'm trying to keep you from doing is keying up one radio within several feet of the other one. If you have someone that can help you 25 or so feet away that would possibly be better. (just a guess I've seen all kinds of cheap radio front end overload).
K9KLC
Southwest, IL
actually according to the manual it has some kind of "receive/transmit" icon so maybe a video might help. Close ups of the front of the radios might show us if you have CTCSS or DCS enabled also.
K4EET
Chaplain
RadioBoy2025
Please let me know if I need to retake a specific step.
