Need Programming Help
nofdexplorer406
Bedford, Kentucky 40006
I have a Tk250 (G) VHF Handheld unit from Kenwood. I heard it is upgradable to 160 channels from my 32 channels. I talked to my local radio dealer Radioland and Kenwood. Kenwood told me it is a software change so I talked to Radioland and they told me it was gong to cost $300 plus to change the unit to 160 channels. Is there anyway I can change to 160 through the KPG23D DOS Version. Any Help is Appreciated.
Phillip Garrett
(C) 502-662-1087
(H) 502-222-0780
email:cfrdstation3ff@bellsouth.net
Muhlenberg County, KY
Okay.....If you have the KPG23D program and a programming cable, you are one step closer...
First, you need to startup the program (NOTE:: THE KPG23D PROGRAM WILL NOT RUN UNDER DOS IN WINDOWS XP!!!! YOU WILL NEED TO REBOOT YOUR COMPUTER STRAIGHT TO DOS!!!!)
When you have the program started and get to the program screen,
1) Press "ALT"
2) go to the MODEL menu
3) Select the model you have/want...e.g. TK-250 (32 CH), TK-250 (160 CH), TK-350 (32 CH), TK-350 (160 CH).....Keeping in mind the model (250 or 350) you have to program
4) hit enter and start writing your program. It will change the software pertaining to the channel capacity when you write to the radio itself.
If you run into any problems, don't hesitate to email me.... searchrescueff@comcast.net
P.S. I would definitely go talk to those people at Radioland....charging you $300 just to plug up their computer to your radio, and change something within the software taking 5 minutes tops.....can we say IGNORANT FOULS!!!!!!!
alan24
Moscow
i"ve got the problem in TK-250 programming.After accidental button pressing i got the message on the LCD "PROG". I cannot exit this mode. Turning the radio off then on doesn't solve the problem. It's just "FROZEN"! Then i tried to update the firmware but with no success.DOS shows "ERROR WRITING WHILE WRITING".Strange error. The right COM port was activated. Any idea on how to make the radio work?
Didn't even realize that archived threads went back this far.
I've had this problem. And I can only offer two words, BAD PROCESSOR!!! So here's the bad news, the parts, time and labor would be too great to replace that bad boy IF you could find someone to do it and find the part. The good news, it's a lot easier and cheaper to replace it. Sorry.:(
nofdexplorer406
On another note had to order a new cord my old one separated from the board cheap ass solder. So its on its way first class mail. And i am gonna do again what I asked to began with lol. My old FD lost their license and changed Freqs and i am now on a really good department that provides everything so i have to transfer this nice radio into a Scanner sort of speak. I am gonna made a Bank of Scanner Freqs and a hidden bank or the Same Freqs with TX as well as PD
KE4ZNR
Radio Guru
Welcome to RR.com Alan24...here is your first lesson in how the forums work...please do not bump an almost 3 year old thread. Your response and question had almost nothing to do with the original topic.
Closing this one.
Thanks for understanding!
Marshall KE4ZNR
