Need to mount two DIN radios in my 2004 Toyota Tacoma
W2IRT
West Caldwell, NJ
Hi all,
I would like to remove the factory stereo from my 2004 Tacoma pickup and install a standard DIN sized stereo and my Bearcat BCD996xt scanner. I was all set to get this done when the shop I planned to hire said the dash kit is not quite 2 DIN units high (he said it was about 1.75 or 1.8 units). Since they normally do just car stereos, and not 2-ways or scanners, he didn't know what to advise me to do and frankly I'm stumped myself.
Has anybody successfully mounted a 996 or any similarly-sized scanner plus a stereo in a 2000-2004 series Tacoma? I've seen a lot of 2005+ installs, but haven't found one yet for my year.
Any thoughts?
Thanks!
PACNWDude
I had a 2000 Toyota Corolla with an almost double DIN opening as well. It had a factory stereo on top and a small storage bin underneath.
I bought a Nissan Sentra double DIN install kit and put a new stereo on top. I then modified the bottom portion to fit a DIN sized RS scanner. This combination fit the opening in the dash, but the trim piece needed to be cut back about 1/8th inch around the outside edge of the scanner to fit back on. I then just put some black door trim piece around the outside edge to make it look finished.
This vehicle has been gone for a while. If I find any pictures of it, I will post them.
It is a lot easier on newer vehicles with true double DIN openings.
PACNWDude
In my "Radio Shack" pictures on my profile I show how I stacked two Vertex VX-3200 radios in the storage bin in my Pontiac. Did it almost the same way as a double DIN. I just bought a spare storage bin and cut it up to fit radios.
hill2jb
Virginia Beach, VA
Good luck
Yeah, I did it in my 2008 and it took a while to get it right. You might have to first see if there is a faceplate that will fit your truck, then see if it is 2 DIN wide/tall. After that, it's easier to find a way to modify existing mounting brackets to fit the gear you want to install. It took me two sets of mounting brackets and faceplates to get a combination that worked.
W2IRT
West Caldwell, NJ
From what I understand it's not QUITE 2 DIN units high, and that's the problem. The aftermarket dash kit is 1.8 DIN high, so there will be some customization required for sure. I'm content to let a pro do the work, but I just want to know if it's even doable.
Kirk
DB Admin
Yep. I have a 2002 Sequoia and had to enlarge the opening a bit (I have an aftermarket DIN stereo and a 996T). I used a sander. A Dremel with sanding wheels would have been better.
Thayne
I did it too, but had to trim the bezel a bit and bought some stock brackets from Toyota parts; you can also get a new bezel if you ever want to put it back to original---
W2IRT
West Caldwell, NJ
Sorry, having trouble visualizing what you mean by the bezel. Any pics of a 2000-2004 install would be greatly appreciated here.
Thayne
Sorry, by the Bezel I meant the whole piece of plastic that includes the 2 vents with louvers and goes around the radio & storage box (if so equipped)
Sorry no pix
Kirk
DB Admin
hill2jb
Virginia Beach, VA
The other thing you could think of doing is maybe getting a remote head for the scanner, and mounting that on the dash, with the scanner body under the seat. I know it's expensive, but it might run you less than trying to fabricate something. Check out my thread on 2008 Tacoma Scanner install. That was with a full 2 DIN compartment, and it BARELY fits in there. I wouldn't do it any other way, but just be aware that it did take a lot of frustration. While you're at it, I would highly recommend wiring it straight to the battery.
Thayne
That pix above shows exactly why you have to hog out the bezel--the scanners are a little bigger on the face than the stock din radios.
W2IRT
West Caldwell, NJ
I got mine in, finally, at a pro installer along with a modest AM/FM. Nice and solid, no rattles or other troubles. I had them wire it always-on and had the orange wire connected to the headlight switch, but my vision kinda needs the full brightness at night so that got clipped a week later.
nyair1
Hi all,
Any thoughts?
Thanks!
Did you look online at crutchfield.com to see if they offer a double din mounting plate for your truck? They sell alot of different car stereo stuff. There is a page you can go to and put in the year and make and they tell you what will fit in the dash. Pretty good site for install info.
W2IRT
West Caldwell, NJ
Chris, see the pic above; that was the final installation by the local shop. They only needed to grind down the bezel about 1/4" to fit the 996 and the stereo. Very very happy with the final result!
W2IRT
West Caldwell, NJ
SAMM Sound on Bloomfield Avenue in West Caldwell. If you have a straight double-DIN opening -- my truck didn't -- it will be a simple installation for them; probably an hour or thereabouts. They had to do a custom job on my truck since the opening is about 1.8 DIN high. With the new car stereo and installing the antenna, the labour was 5 hours.
