I just added a Yaesu FTM200D to my boat... and due to the difficulty of mounting/changing the existing marine antenna, I decided to use it with this Yaesu. My meter is showing 1.8 to 2.5 SWR across both 2m/440 ham bands and believe it or not, even the GMRS frequencies... (which had the highest SWR@ 2.5)
The current antenna is mounted to my radar arch and there is very little room inside the arch to manipulate coax/fittings/etc... so I'd like to leave it as-is. I will add a 2nd antenna on the side of the arch and make that the main antenna for the marine radio.
My question is... should I live with the current SWR numbers ? or should I trim the antenna and try to tweak the SWR down more ?
This is the antenna in question:
