ClemsonSCJ
- Joined
- May 29, 2018
- Messages
- 227
Ok guys, I’m jumping into this amateur radio thing completely fresh and know virtually nothing about it (I catch on quick though). Wife and I are in the process of studying up to get our technician and I’ve bought a couple Baofeng UV-5R’s to start listening and learning. I’ve got 4 radios total, 2 will stay in each of our vehicles and the other 2 will stay in the house. I’ve gotten upgraded Nagoya whip antennas for each radio and they have a surprising amount of range. Disclaimer: I know I’m not supposed to be using them without a license, this was only a quick range test and we have only been using them to listen to local repeaters outside of this test. Anywho, with the upgraded whips I was able to get 2.5 miles straight line distance with both of us outside before I quit trying to go any further. Voice was clear as a bell at that distance and since our use is mostly going to be for camping/hunting and bugout/emergency purposes, I didn’t feel the need to go beyond that distance.
I have noticed, however, that inside my Grand Cherokee I have to be within 1/4 to 1/2 mile to make decent contact. So I’d like to see about getting an antenna to mount on the roof and attach to the UV-5R in my Jeep and her car to make sure we’re optimizing ranges in our vehicles. I thought it was gonna be a simple decision but learning about antennas alone, let alone amateur radio in general, is like drinking from a fire hose.
I will probably just do a magnet mount antenna on my wife’s car cause I know she’s not gonna want it to stay on there all the time. My Grand Cherokee, however, will be on there permanently. So I need to know what antennas you guys would recommend. We live in a fairly mountainous area so when we do get licensed and start communicating through repeaters, most of them are high up on mountains. I only say that because I have done hours of research trying to figure this out on my own and one bit of reading I did said that 1/4 wave antennas do better if the receiver is greater than 45 or 60 degrees above you. Again, I know literally next to nothing about this so if I’m sounding like I read some BS then disregard. Outside of that my only criteria is to keep it under 40” or so. I have a CB antenna that’s a Wilson 61” whip and it’s just barely long enough to catch stuff I do on a regular basis, like chick-fil-a’s covered awnings and what not, so I’m planning on shortening that as well. I’d like to maximize the ground plane of my roof for both the CB and VHF/UHF antennas so is there a minimum distance the 2 antennas need to be spaced from each other? I have a sunroof so that somewhat limits my space but there’s still a fair amount of roof space, but it will get cut down quick if I have to keep these antennas far apart.
I know that was a little long winded but just wanted to make sure you guys have what you need to make an informed decision. Thanks in advance.
