S
simpilo
Guest
I know you like your PRO-2020. I like your PRO-2020. How audio is treated in a scanner from it's era before digital was in. They hadn't thought about that in the design. If you are handy with a soldering iron and schematics then mod it for a better audio frequency response. If not may I suggest ordering one or two of these. This is the sure way to do what you need to do without having to spend $300-$700. Drawback is you will have to be at the pc to listen. Not ergonomic for portability. There are ways to do it portable but takes some doing to make it work on a Android. Like making sure it will even work with 'on the go' adapters. Concentrate on PC use because it's easiest to get going.
www.nooelec.com
Nooelec - Nooelec NESDR Mini 2 SDR & DVB-T USB Stick (RTL2832 + R820T2) w/ Antenna and Remote Control - SDR Receivers - Software Defined Radio
<p>Say hello to the newest member of Nooelec's popular NESDR SDR-range, the <strong>NESDR Mini 2</strong>. The Mini 2 uses a brand-new tuner IC, the <strong>R820T2</strong> made by Rafael Micro, to provide <strong>increased sensitivity and improved SNR</s
