New 700 mhz freq
MBECKNELL
Hamilton,Ohio
hey does any one know if the following freq maybe part of the states 700mhz p25 system
here is a few i found today
792.26250-control
792.259375
792.253150
793.059375-control also i believe
was p25 auto in tune mode with my pro 106 in butler county
please give me input
wa8pyr
Staff member
Lead Database Admin
Ohio
Any trunked system received on a RS/GRE scanner between 776-806 MHz is an image of 800 MHz signals
Incorrect. The PSR500/600 are perfectly capable of receiving legitimate 700 MHz frequencies; I listen to them every day.
wa8pyr
Staff member
Lead Database Admin
Ohio
792.26250-control
792.259375
792.253150
Legitimate 700 MHz channels at this time have 5 digits following the decimal point. Make sure your search limits are set for 769.00625 (lower) and 774.99375 (upper) with a step size of 12.5 kHz.
Thunderknight
Bletchley Park
I think the important detail here is he said 776-806. You would not hear a real trunked control channel there. The 700 MHz narrowband base transmit (e.g. control channels, repeaters, talkaround) is 769-775. The matching mobile/portable transmit (input) side is 799-805 MHz.
So outputs and control channels for 700 systems would only be found in the 769-775 segment.
This was actually done for a reason, as it allows the LMR mobiles and portables that are 700/800 radios to have their transmit section from 799-824 MHz to cover both 700 and 800, and then implement either a wideband receiver or dual receivers (one for 700 and one for 800).
(A little side note: There may be a couple of systems left in country in the 764-769 "old" narrowband segment, but that is still below 776 anyway).
