I may be moving to Bozeman, the feed will be very helpful until I get my stuff set up.
Any word on when they might go digital?
Thanks,
E.P.
Good luck on your move! Bozeman is still a great place. No word on when, but I do know almost all the LE have the new digital radios. MHP car to car is encrypted from time to time. I know Bozeman will be switching over soon. Talks with officers confirms this. Lets hope that at least dispatch stays in the clear. I love listening to what is going on.
Thanks, I was there over the summer it is definitely quite the place.
I guess a digital scanner will be a must, what works best for the area, what are you using?
What about MSU’s communications?
Thanks for any information.
bdar15, did you get my PM?
Thanks again for the feed.
I second that. Thanks for adding the sheriff North ch.
Belgrade and the other small communities PD use sheriff North, as Fire North channel has most of the dispatch for the Northern Gallatin co FDs, once the department is organized/responding they will switch to a Fire tac channel. Usually calling out "ops on G(gallatin) F -tac1". Fire Departments hardly use the 10 codes, but do alot of readbacks(conferming of the conversation)
Check out the wiki for the county. I'll work on getting the list of the "10" codes into the wiki as most of them are a 3 digit code begining with 9. 904 is 10-4. I moved here from wisconsin, back east they used all the 10 codes for the state.
Still analog on 3/22/11.
I noticed there was more traffic, do the other dept. fire etc... use 10 codes as much?
Also any update on digital? I do not have a digital scanner and would like to go for as long as possible with out having to buy one. If I do get one it will likely be a pro-106.
Thanks for any info.
Bozeman is in the testing process right now. City PD will be the first ones to move to the new system. Not sure what their policy will be on encryption at the moment.
Have you heard the testing on the air? I haven't been monitoring during the day as much, but still listen in the evenings.
