I have a pro-2096. I live about 3mi. south of Detroit border (Southwest Detroit) I have an 800 MHz ant. I have 23 channels for Det. set to Rx mode=MOT, no delay, no atten, I have read about simulcast and understand a little. Most of the time the channels are garrbled. I'm looking to see if there is anyway to improve this. I don't want to get into the time and expense of an outdoor ant. for 1 channel. I only want to pick up Southwest Detroit. Please keep it simple, I'm new at this. Thanks
Ps I also have the DSP 1.4 upgrade
GMAN,
You did not state if you have an outdoor antenna or if you are using the rubber ducky antenna? As was stated by supernoma, your best bet to monitor Detroit is with a yagi(beam antenna) with as much gain as possible. Height will also help you out. Being that you are only a couple miles out of the City, with a yagi you should be able to pull the system in with little problems.
Now, the second issue is the PRO2096. I use to own these radios myself, however I upgraded when GRE released the PSR500 and 600. The 2096 is plauged with a problem called Motorboating. Radio Shack offered no firmware upgrades to correct this problem and left everyone hanging. I would highly recommened if you can afford it to sell your 2096 and purchase a PSR600. You will find that it does much better on the Simulcast Systems and will not motorboat. Motorboating is not the only issue, but like the others have said the Detroit Simulcast has 10 tower sites, but was designed to operate in the city and only about a mile outside or behind the tower. This was done because they could not interfere with Cananada.
Should you need more help, please PM me or post here. Hope that helps.
