New Jersey Convention Center
jaymatt1978
Cape May,NJ
Anybody have a good list of frequencies for the state convention center in Edison? I can't listen to t he township with the 246T, but was hoping to pick SOMETHING up while I was down there! Otherwise I'll have to just rely on close call, which never lets me down! :cool:
Thanks in advance
robbinsj2
Bridgewater, NJ
Convention Center Ch-1 464.5000 M D114
Convention Center Ch-2 464.5500 M D115
Convention Center Ch-3 469.5000 M D116
Convention Center Ch-4 469.5500 M D122
(copied/pasted from the table on my web site; formatting may be bad but info should be good)
Don't forget that you CAN listen to the multicast of fire dispatch and EMS dispatch on the (analog) conventional channels.
Jim
GM
NJ Convention Center
That info. was personally verified by myself with their radios in my hand doing searches (BC296D) so it should be accurate. NJCC seldom uses them except for large scale events. Edison TRS is mixed mode, so you can listen to DPW and PD Auxiliary (rarely used) channels in analog as well as the multi-cast of the Fire Main & EMS Main channels, as already mentioned. There's been a number of forest fires in that area recently, (since it borders the Salt Marsh habitat) so you may want to have the State Forest Fire programmed in as well, if not already in the event a fire occurs.
Greg
elk2370bruce
East Brunswick, NJ
Greg. In which incarnation are you presently in? You confuse me in my antiquarian state (state of confusion usually)
jaymatt1978
Cape May,NJ
Alright Jim!! Thanks for the information I'll let you know how I make out!!!!!!! Yes Greg I do have the NJ forest fire frequencies in there. Maybe I'll add the NJSP C Trunked System in for good measure!
