| 15084 Jackson Rd, Zachary, LA |
| 1 (1) | 028 (1C) | Baywood | East Baton Rouge | 769.10625 | 770.18125c | 770.43125c | 772.40625 | 772.63125 | 773.18125 | 773.38125 |
| 773.55625 | 773.80625 |
No that is the Baywood LWIN tower It's really in Pride but has a Zachary address. It's only a mile from me I listen to it without a antenna. It' been there probably 20 years. This new LWIN tower I'm asking about is on Port Hudson Pride Rd. in Zachary. It's online now but it's not listed in RR yet.Are you talking about the tower listed with a
address in the database as:
1 (1) 028 (1C) Baywood East Baton Rouge 769.10625 770.18125c 770.43125c 772.40625 772.63125 773.18125 773.38125 773.55625 773.80625
About everything that comes across that tower. Almost everything in Louisiana is on LWIN. All our local LE, State LE, Fire Depts.What are you using to try and listen to the new tower?
I have a few scanners mainly using a Uniden 200 and Whistler 1065 and a few moreI meant what scanner are you using. If a SDS series and you have the waterfall option you could try to look at the signals on the 700-800mhz and identify the channel then check against the LWIN listings for anything new in your area.
If you use SDRTrunk, you could look under the Details tab and see what systems are listed as neighbors to the Baywood tower and note the channel and then compare to the LWIN listings to see if it is a new control channel. Or use the waterfall as described above.
Other than those two options, just have to wait till someone id's the control channels and updates the database.
You might be able to find the FCC license for the site. Possibly this license granted in Oct 2024? The tower is located off of Port Houston Pride Rd in ZacharyNo that is the Baywood LWIN tower It's really in Pride but has a Zachary address. It's only a mile from me I listen to it without a antenna. It' been there probably 20 years. This new LWIN tower I'm asking about is on Port Hudson Pride Rd. in Zachary. It's online now but it's not listed in RR yet.
