Ship him a radio. I'm sure he would be happy to host one for you.
Yeaaaahhhh.. If I wanted another jumbled mess of a feed with every frequency and TG within a 100 mile radius I'd set it up myself, jackass.
His equipment his feed.Bottom line he can feed what he wants.If you had bothered to read, I'm not bit ching, 40 watt. I'm trying to help him out, because right now his feed is an insufferable mess - and he's trying to justify it being a mess due to the fact that "scanners have thousands of channels, so why not use them". He is not grasping the concept that you can't do that on a streaming feed where the listener isn't in control of the scanner, and that the scan list has to be as lean as possible in order to catch meaningful conversation..
Hello Kansas!
I'm not the one to listen to online feeds but I brought this one up as I ran across this thread and the discussion.
Some observations:
There seems to be the perfect amount of talkgroups/channels being streamed for the amount of talking they do. Trimming it down to fewer areas as the one guy feels is necessary would make a very boring feed. (There was a significant amount of dead-air time already with the feed the way it is now over the 15 minutes that I listened to it.)
That said, the feed is overmodulated. Too loud causing distorted audio.
There is one analog fire dispatch on the feed that is so weak it was impossible to make out anything that was said through the noise.
Thanks for adding Ellis County to the feed. I have cousins out there who no longer have an operational scanner, so this will help them. Just an FYI, Life Star no longer uses the UHF repeaters to tone out their helicopter crews. Everything is now on KSICS (1665-East/Lawrence Base and 1666-West/Junction City Base). Might be worth deleting those unused UHF frequencies unless you feel the need keep those plugged in.
Occasionally I'll even pull the Hays talk groups down here in Hutch, but it's few and far between
Back of set antenna. I live right in the middle of Downtown Hutchinson, right next to the Amtrak station. I pull in Troop C and E on occasion. I think I've even gotten some Troop D mixed in.
No crap?! Not the default/original whip, must be an upgrade! What kinda rig you running?
I have a Pro-652 and a 106 with the same channel layout. No antenna upgrade on the 652, however I do have the RS 800 ducky on the 106. I think a lot of my traffic I get from there has to do with when I have someone from that area down at KLETC, which is about 10 miles southeast of town.
It don't do too bad on the v/uhf either.
