stingray327
What kind of scanner is required to monitor Oakland PD? Digital? AP-25? What is AP-25?
It's a P25 800 mhz digital system.. You need a digital scanner. ie. BC996XT
Do you receive the OAK P25 with your BC996XT?
I've heard from a few posters that the BCs DON'T work with the OAK P25 System, however the GRE 500-600-800s do.
If this is the case and you want to monitor the OAK P25 system you you need to get a GRE not a BC.
Dave
I am using freescan with my 396XT, do I set it for Mod type II/P25? or P25 standard (digital XT) or P25 One Freq Trunk (digital XT)
I noticed a couple of weeks ago when I checked in on OAK P25 to see if anything new was up and found that Gwin site 101 was down and had been for a while, pro96com listed it as stale, and noticed same as above poster said, what sounded like CC and Voice mixed together on all transmittions and Freqs from site 202 Broadway.
Now I also find NO CC.
Dave
I am not receiving P25 broadcasts for Oakland Police/ Fire on my GRE PSR 500.
Others have suggested that I may not have the necessary primary and alternate control channels.
I had the scanner programmed by scannermaster when I purchased in December and have since tried to repair the problem using using Blu-Tel Arc 500 software and a Radio Reference subscription.
Is there a problem with the new system at present that requires some special programming to resolve?
I am assuming that the Broadway site is the primary (or only) broadcast site at present .
Thanks in advance for any info.
If they are incorrect, how about submitting the correct ones ?![]()
