A satellite, most any satellite once parked in center of box will be pushed and pulled around by earths gravity and solar winds where it starts moving in an ever growing figure 8 pattern. About every 2 weeks the people who fly the satellite will command the spacecraft back to center of box and this cycle repeats for the lifespan of the spacecraft. The main thing that determines the useable lifespan of a spacecraft is not its electronics or battery, its how much station keeping fuel it has on board at launch by design and from use during unusually busy station keeping maneuvers.
Most companies with C band dishes over about 9m in dia have the dish in a "step track" mode where it peaks itself anywhere from every 10min to 1hr depending on design parameters, the more often wearing out parts faster and less often putting you at some risk of signal degradation. The earth station I worked at for 18yrs (I retired as the principal RF engineer) I locked down our 11m C band antenna at center of box when first installed and its never been moved in over 20yrs now because there was no perceivable degradation as the satellite does its dance and I avoided lots of wear and tear by parking it.
For Ku band and higher the 3dB beamwidth of the antenna will be smaller than C band and most antennas over about 6m diameter will need to track the satellite. I had two 13m Ku, one 11m C, one 11m combo C/Ku two 9m Ka, two 8m Ka and a 7m Ku, all uplink and a bunch of receive only antennas at my site. The larger Ka band (28-30GHz) dishes are soo pointy they use a "monopulse" tracking which is a continuous servo track where if the antenna moves in the slightest its pushed back right on boresight to the satellite instantly.
For this new dish at McMurdo its complicated enough to require someone assigned to it on a 24/7 basis. If its step tracking and carrying important information, an accidental glitch in the tracking can swing the dish off the satellite and it takes someone who knows what their doing to put it back. There is also periodic maintenance checking RF levels a couple of times a day and changing gear oil and lube every 6mo, etc.
If its a transmit/uplink antenna there is a lot of support equipment and high power microwave RF to deal with and periodic maintenance on all that which takes an expert in the field to maintain, align and replace when needed. Over time the cost in maintenance personnel and replacement equipment will greatly exceed the original cost of the antenna.
And you will need to do "center of box" tweaks probably twice a year. Brings back a lot of memories. Think the crew included Jose ?
