VIPER system, this month, is P25 Phase 1, however next month it is changing to a P25 Phase 2 system.Just moved to NC and was told I need a new scanner to listen to local FD. They use VIPER system. What brand and model base/mobile units are out there to consider? I know nothing about the VIPER system. Thank you
Like many things in life, it depends … on which scanner you have. Some scanners support phase I and II, others only phase I.Is It the same scanner if they change?\
According to this: North Carolina VIPER Counties Verified - The RadioReference WikiJust a thought, since you are in Lincoln County you need to think if you would want to listen to surrounding areas. When you say Denver, I automatically think of multiple areas around Lake Norman you may want to listen to. Iredell County will be going to a simulcast on VIPER. Charlotte/Mecklenburg and some of Gaston County use UASI with Charlotte/Mecklenburg being simulcast. Catawba County uses VIPER but I can't remember if they are simulcast or not. If you have any interest in listening to these, you will want to get one of the Uniden SDS 100 or 200 scanners. Just a thought.
As noted Iredell will be a simulcast on VIPER. Don't forget the Gaston County simulcast on VIPER which covers well into Lincoln County. One really should consider the modern LSM IQ receiver scanners for most areas as simulcast become more prevalent not only on the state system but the local systems that are already in place like UASI, Rowan, Forsyth, etc.Just a thought, since you are in Lincoln County you need to think if you would want to listen to surrounding areas. When you say Denver, I automatically think of multiple areas around Lake Norman you may want to listen to. Iredell County will be going to a simulcast on VIPER. Charlotte/Mecklenburg and some of Gaston County use UASI with Charlotte/Mecklenburg being simulcast. Catawba County uses VIPER but I can't remember if they are simulcast or not. If you have any interest in listening to these, you will want to get one of the Uniden SDS 100 or 200 scanners. Just a thought.
IS this ALL Viper in NC?VIPER system, this month, is P25 Phase 1, however next month it is changing to a P25 Phase 2 system.
Sorry I have to ask but if you have a SDS200 scanner what do I need to do? Will the SDS200 just keep running or will it need to be reprogrammed?
Thanks for any help!
Thank you sir!......VIPER is one system throughout the state, so yes it is ALL viper. You should not have to do any reprogramming, it will work just like it does today.
What a freaking coincidence! You are Bradley Hyman and the contact info on the FB page is bhyman@XXXX.com. What are odds????This person does a great job program and scanners Police Scanner Programming Expert | Lake Wylie SC
