OK I have the WIDE BAND OMNI X....it works very well pulling in vhf/uhf PD and FD depts I listen to in Rhode Island and Southeast Mass. It pulls in those distant vhf hi rural fire departments northwest of me.DPD Productions makets two different "Omni" antennas. One is considered a wide band general scanning antenna. The other is called the "MilTenna Omni UHF/VHF Base Antenna" which is designed and optimized toward VHF and UHF aircraft bands, both civilian and military. It would not be a good choice for the 700-800MHz bands. The regular Omnix X would be the better choice if you're also wanting to use it for the 700-800MHz bands.
OmniX Scanner Base Antenna
Specs Gain: 3 VHF 4 UHF dBi Pattern: Omni-directional Wavelength: 1/2 Elements: 3 Tuned: 118-137, 148-175 & 225-900 MHz Band: UHF & VHF Connector: N Female Cable: RG8X Cable Length: 16 Inches Height: 45" Width: 30" Weight: 2 lb Features Multi Band-Wide Coverage: The uniquely...dpdproductions.com
Air Omni UHF/VHF Base Antenna
Specs Gain: 3 VHF 4 UHF dBi Pattern: Omni-directional Wavelength: 1/2 Elements: 3 Tuned: 225-400, 118-137 & 138-140 MHz Band: UHF & VHF Air Connector: N Female Cable: RG8X Cable Length: 24 Inches Height: 45" Width: 30" Weight: 2 lb Features Tuned to UHF & VHF Air Bands: The uniquely...dpdproductions.com
