SouthOrRadio
Should be released this Friday, $160 on Amazon.
Amazon.com: Tecsun PL880 Portable Digital PLL Dual Conversion AM/FM, Longwave & Shortwave Radio with SSB (Single Side Band) Reception: Electronics
Link to the manual...
http://swling.com/blog/wp-content/uploads/2013/11/Tecsun-pl880-Manual.pdf
Tecsun pl-880
High Performance World Band PLL Synthesized Multi-band Receiver
Details
TECSUN’s latest high-end radio receiver has arrived: PL-880. Equipped with analogue High-IF circuit, multi-conversion and DSP decoding technology, PL-880 has great performance in its sensitivity, selectivity and the interference of mirror stations (image rejection). Besides these technological advances, the introduction of the Auto Sorting Memory function in Tecsun’s latest top receivers provides greater user friendliness and convenience in using stored stations. And to further enhance listening enjoyment, PL-880 is fitted with Class AB type Audio Power Amplifiers and ultra-dynamic full range speakers.
Special Functions:
Multi-conversion processing of incoming radio signals to reduce interference.
SW Single Side Band (SSB): individual reception of Upper Side Band (USB) and Lower Side Band (LSB)
Auto-sorting memory: sorting stored stations automatically according to meter band and frequency, removes duplicate stations.
Frequency Range:
FM: 64 – 108 MHz (Russia) / 76 – 108 MHz (Japan) / 87.5 – 108 MHz (Germany)
MW: 522 - 1620 kHz (band step 9 kHz for Asia / Africa / Europe)
520 - 1710 kHz (band step 10 kHz for Americas)
LW: 100 KHz to 519 KHz (tuning step 1 kHz or 9 kHz)
SW: 1711 KHz to 29999 kHz (tuning step 1 kHz or 5 kHz)
Tuning Methods:
Auto / manual tuning for stations within frequency range (VF mode)
Auto / manual tuning for stations within its memories (VM mode)
Direct keypad entry of a frequency or memory address
Storing Stations Methods:
Manually: tune into a station manually and store them
Semi-auto storage: storing stations during auto-scan
Auto Tuning Storage (ATS): automatically tune into and store stations
Basic Features:
Multi-functional Digital Display shows:
Meter band & frequency
Memory page and location
Signal indicator: S/N ratio and strength
Clock & Alarm
Battery indicator
3050 stations storage locations, divided over 25 memory pages
Manual tuning control: Fast, slow and fine-tuning
Alarm by radio, and with the automatically alarm stopper within 1 - 90 minutes
Snooze function – 5 minutes, repeated three times
Sleep timer from 1 - 120 minutes
Class AB type Audio Power Amplifiers & ultra -dynamic full range speakers, with excellent sound quality
News / Music tone switch
LCD backlight
LCD light on/off switch
Key lock function
Vertical back stand
Local / Norm / DX antenna gain switch: adjust sensitivity when using external SW antenna
SW (& FM) antenna jack
Line-out jack
Earphone jack (3.5 mm)
Speaker (40 mm)
Built-in Charging System to charge lithium (Li-ion) rechargeable battery
Mini USB DC jack (5V / 500mA)
Power supply:
Battery: 3.7V 18650-type lithium (Li-ion) battery (included);
External power source: USB switching adapter with double entry (5V/1000mA & 5V/2400mA) (included)
Unit size 192 x 113 x 33 mm (W x H x D)
Original accessories: 1pc stereo earphone, 1pc SW wire antenna, 1pc protective carrying pouch, 1 pc charging cable, 1 pc Amateur Radio World Map, and English manual.
Sensitivity:
FM (S / N = 30dB) < 3uV
MW (S / N = 26dB) < 3mV/m
LW (S / N = 26dB) < 5mV/m
SW (S / N = 26dB) < 20uV
SSB (S / N = 10dB) < 3uV
Selectivity (Factory default of AM IF bandwidth to narrow band):
FM > 35dB (± 200kHz)
MW / LW > 40dB (± 9kHz)
SW > 40dB (± 5kHz)
S/N Ratio:
FM > 65dB
MW / LW > 40dB
SW > 45dB
Tecsun pl-880
Details
Special Functions:
Frequency Range:
Tuning Methods:
Basic Features:
Clock & Alarm
Battery indicator
LCD backlight
Key lock function
Vertical back stand
Line-out jack
Speaker (40 mm)
Power supply:
Sensitivity:
SW > 40dB (± 5kHz)
S/N Ratio:
FM > 65dB
MW / LW > 40dB
SW > 45dB
