new Texas Interoperability Channel Plan
K5MAR
Stillwater, OK
OK, Tom, we've already discussed elsewhere one "mistake" in this plan, the reversal of the input and output in the 800MHz NPSPAC freqs list (at least I HOPE this is a mistake!). You mention some other errors in this document. I haven't had a chance to really read it, can you elaborate?
Thanks,
Mark S.
nd5y
Wichita Falls, TX
I think the 700 MHz channels may be screwed up.
the inputs & outputs appear to be backwards on some. As far as I can tell
they are supposed to be high in low out on that band, and the last 2
channels listed aren't 30 MHz offset either. Something is weird about the frequencies too.
They are different from the ones listed on this document:
http://www.npstc.org/documents/Appendix A - Tables of Interoperability Channels-corrected.doc
I'm not sure if PL tones are really supposed to be used now on
TX FIRE 1, TX FIRE 2, TX FIRE 3, TX LAW 3, and TX MED 1
They have always been carrier squelch before and this conflicts
with the immediate interoperability plan from 2 years ago.
The VCALL and UCALL channels, from what I have seen in other
documents, are always supposed to be carrier squelch.
On p. 4 they left off the last number on one of the callsigns.
On p. 29 the UHF table doesn't have cell border outlines.
If this is really the official release of this document, It looks to me like
somebody should have reviewed it before they approved it.
Tom
K5MAR
Stillwater, OK
WOW!! :eek: :eek:
OK, who's going to tell the emperor he's got a clothing problem? :lol:
Mark S.
n4voxgill
Silent Key
New Braunfels, TX
A discussion was held during the National Coordinating Committee meetings to reverse the input on 700 MHz, but that was turned down in the NCC and as far as I know the FCC is aligning input 45 MHz below output
nd5y
Wichita Falls, TX
Reversed from what? The latest documents I can find all say base transmit
764 - 766 and mobile transmit 794 - 806. That is a + 30 MHz offset.
Tom
K5MAR
Stillwater, OK
Mozilla
South Florida
155.475
Well, 155.475 is supposed to be the National Law Enforcement Emergency Frequency and its supposed to be carrier squelch... We ran into this during an inter-operability drill down here in FLorida where almost every local agency had put a PL ( yes a different one for each agency) on this frequency and also 155.3700 and 154.950...
Thankfully the majority of our users had either System and regular Sabers with MPL lists or we had front face programmable radios and could adapt to theirs.... a few even had monitor / carrier squelch disabled :oops: Downloaded the plan to read all the way thru but its definitely a positive step towards interoperability.
Stephen
Columbia, MO
In the report it talks about the conflict that you brought up about the PL tones in there it says that all agencies using PL tones should be capable of also using a "monitor" mode in which they can hear agencies using the CSQ mode.
K5MAR
Stillwater, OK
Thanks, Tom! I downloaded it the other day when you posted the link on DFWScan, with my dialup it took about an hour! Nothing I wanted to do a second time unless there was a significant change.
Mark S.
nd5y
Wichita Falls, TX
It changed again today.
Now they have this message:
NOTICE: PLEASE DISREGARD ANY VERSIONS WITH AN EARLIER DATE
THAN APRIL 1, 2005! I AM SORRY FOR ANY INCONVENIENCE, BUT
PREVIOUSLY DOWNLOADED DOCUMENTS NEED TO BE DESTROYED
AND A NEW DOWNLOAD DONE.
I removed the filename references in my earlier posts.
Just download it from the main page.
http://tsiec.region49.org
Tom
