Hi all -
I just received my previously loved SDS200. Coming from a Pro-197, this is quite the upgrade. I definitely had to learn a few new ways of programming! I have both Sentinel and ARC536, and as noted elsewhere in the forums, ARC536 is definitely the winner in ease of use, but it just can't totally replace Sentinel for some of the scanner programming.
To that end, there are two things that I just cannot seem to figure out how to correct:
1) When the SDS200 picks up audio, every 2 seconds or so, the audio will stop, and then pick back up again. Almost like it was checking for a priority channel, yet I have no priority channels programmed, and I have priority scan turned off. Am I missing something? This is something that is really annoying.
2) The LED. On the Pro-197, once the LED is lit, it will stay lit as long as the channel is active, then turn off when the channel clears. On the SDS200, the LED lights, but then regardless of how long the channel is active, it will shut off after a few second. Is there anyway to fix that? Not a big deal, and certainly not nearly as annoying as #1 above, but curious about it.
So far, overall, I like the scanner. I bought it because Iowa seems to be moving to P25 Phase 2, but of course, there doesn't seem to be anything out here to listen to yet. I guess I'll at least be prepared for the future.
Sean - K0MSM
Sean - K0MSM
