New to SDR, checking in
jmayson
Austin, TX
My RTL-SDR arrived the other day. So far I have accomplished...
1. Conventional scanning on my Chromebook.
2. HF reception on my Chromebook.
3. Conventional scanning via an app on my Samsung S9.
4. DSD+ on Windows 10, monitoring P25 TRSes around me.
5. I wrote a pushbutton GUI for DSD+ to switch systems.
I'm rather impressed as I can pull in an LCRA site in Hays County and I'm in northeast Travis County (at least 30 miles/50 km away).
I ordered a cheap Windows 10 tablet and I'm planning on dedicating it to scanning. It has full blown Windows 10 Home and a USB port, so I have to think it'll work.
Still to do...
1. EDACS scanning (I have no systems around me, but do visit areas that do).
2. Mastering GnuRadio. I'm an old UNIX/Linux guy and I'm completely lost.
bobruzzo
W1AV
Cranston, Rhode Island
4. SDS+ on Windows 10, monitoring P25 TRSes around me.
5. I wrote a pushbutton GUI for SDS+ to switch systems.
Still to do...
I have a chromebook. What software did you use to do all this? I always thought the Chromebook was limited as far as attaching hardware and downloading actual programs.
jmayson
Austin, TX
I have Linux enabled on mine and am running software from that.
I've written up some notes. I did this as I was experimenting, so they could be a little disjointed. I'll clean this page up as I learn more. But most of all, it is possible to enjoy SDR with a Chromebook.
boatbod
Talbot Co, MD
Still to do...
There are gnuradio tutorials out there to teach you the fundamentals of GRC. That said, the real power of gnuradio comes from the building blocks that you use to create your own blocks and apps. GQRX is a full-blown linux gnuradio application similar to SDR#. OP25 and TrunkRecorder are linux gnuradio apps that work with P25 Ph1 and P25 Ph2 trunking systems as well as legacy Motorola Type II (SmartZone).
There's lots to learn; if you really want to get into gnuradio you're going to need to study up on SDR & DSP concepts because the documentation is quite "succinct" (i.e. minimal) and assumes you know what signal processing you want to do.
jmayson
Austin, TX
Thanks. I can probably figure it out. I tend to learn by example. I need to find a few examples and go from there. I just haven't put the time into it. Do you know where I could find a simple example such as FM broadcast or VHF/UHF conventional?
I'll check out the other two. I've heard of OP25, but wasn't sure what it was besides "Open P25".
NebraskaCoder
Omaha, NE
Any good places to start learning DSP and signal theory?
N6ML
NebraskaCoder
Omaha, NE
boatbod
Talbot Co, MD
OP25 can be quite challenging to configure, but once you get over that hurdle is can work with the following protocols:-
- P25 Phase 1 and/or P25 Phase 2 trunk tracking with single or multiple SDR tuner devices (RTL, Airspy, HackRF, RSP... i.e. anything supported by the gr-osmosdr driver)
- P25 Conventional
- Motorola Type II (SmartZone) trunk tracking [boatbod version]
- DMR Base Station (repeater) monitoring
- Moto TRBO Connect+ trunk tracking [boatbod version]
- DStar
- YSF
- NXDN [osmocom version]
lwvmobile
DSD-FME
Lafayette County, FL
Still to do...
This nifty little project might cover that EDACS scanning need of yours, if you ever wanted to do it on that Chromebook, since you're an old UNIX/Linux guy and all :cool:
jmayson
Austin, TX
merlin
DN32su
I use a tablet with my SDR dongle and an app I can't recall what, but does work to a degree.
The problem is needing a 'Y' type OTG cable so I can put power to one input.
Without, the dongle sucks the life out of the battery in a matter of minutes.
lwvmobile
DSD-FME
Definitely sounds like a caveat to using a tablet with one or more SDR dongles. You either use a ton of battery in a hurry, or you use some form of powered USB hub and limit the portability of the device to a degree. Then you spiral into a conundrum of whether you are better off with a laptop that you could plug into the wall or a desktop set up.
jmayson
Austin, TX
This is what I ordered: Amazon.com : 7" PIPO X8PRO Tablet 1280800 Windows 10 or Android OS Intel Z8350 Quad Core 1.84GHz Mini PC HDMI 2G RAM 32G ROM (Single OS Win 10) : Computers & Accessories
What I'm not clear on is if it'll even work without AC power. It's mostly for home anyway. I'll keep this thread posted on how it works out.
lwvmobile
DSD-FME
I don't know, my spider sense is tingling on this one. I kind of got a feeling that this might be a Windows 10 S unit, even though the description doesn't say much about it being S, Home, or Pro. If its Windows 10 S, you aren't going to be able to run any SDR applications on it without converting it to a full blown Windows 10 install, and that will probably eat up a extremely large chunk of that 32GB "ROM", which I'm assuming they mean an eMMC storage block.
