New to the hobby: "Encrypted" indicator in the DB?
N2ZQO
Des Plaines, IL
Hi - Very much a newbie "how to use the database" question, so bear with me.
Are there any "dead giveaways" or other obvious indicators in the database that a system or channel has encryption in place -- or is it down to "trial and error" on the scanner's part (as in, "Given my radio and antenna setup I ought to be able to hear this public safety or police system in my area but it's dead quiet, so probably encrypted"?).
Thanks and 73
N2ZQO
mc48
Monroe County, NY
Under the column for mode, lower case e is partially encrypted, and upper-case E is fully encrypted. Hovering over the mode will show the meaning of the abbreviations.
nd5y
Wichita Falls, TX
A lower case e indicates part time or user selectable encryption.
You can never count on the database being 100% accurate.
N2ZQO
Des Plaines, IL
Thanks all, for your consistent (and fast!) answers. I'll keep an eye on that field and try to close this thread.
GTR8000
NY/NJ Database Guy
BEE00
Note that for conventional listings, the format is slightly different. Any identified encryption will be appended to the conventional mode, i.e. P25E or DMRe, etc. Same concept as noted above, however what was shown was specific to the trunking talkgroup modes of operation.
N2ZQO
Des Plaines, IL
Yes, I caught that difference. Thanks for flagging it!
