AOR has the licensing, that's the sole difference, other than it uses older hardware for channel memory and display functions.
Airports and malls are increasingly using TETRA.
As noted, TETRA is being employed in SDRs and already have an open protocol system developed that could be implemented with ease.
AOR's processing power isn't all that much different, otherwise, from Uniden's. Dedicated TETRA handhelds use even less than either, especially since TETRA was originally developed on much older systems.
But you're so gung-ho on AOR in a Uniden forum, that you've repeatedly put down Uniden and the SDS system as inferior, that I'd expect you'll continue doing so, so not worth my time.
