Will the new battery and drop in charger be compatible with sds100?I would have like the normal Vol knob back where you can adjust the Vol not 1 by 1 and even at 1 still loud if ear buds are being used.
The contacts visible on the SDS150 battery indicate it will not mate with the SDS100.Will the new battery and drop in charger be compatible with sds100?
Bummer, be nice to upgrade the 100.The contacts visible on the SDS150 battery indicate it will not mate with the SDS100.
Where did you see the battery contacts? The photo in post 330 was of a marine radio battery.
The 150's body is different from the 100, so they'd be physically incompatible, and the charger contacts are part of why.Will the new battery and drop in charger be compatible with sds100?
Post #93Where did you see the battery contacts? The photo in post 330 was of a marine radio battery.
Yes, and also have selectable limit settings, like mdevoe suggests, so it never can go below something like 5 miles and above 35 miles for sites.Maybe there should be an ability to have a - (negative) value, just like -5/-10 hold time.
NoWill the new battery and drop in charger be compatible with sds100?
Jason - Just want to let you know how much we all appreciate you taking the time to answer some questions. You're awesome!
Thank you Matt!Jason - Just want to let you know how much we all appreciate you taking the time to answer some questions. You're awesome!
I can confirm, that is not the battery the SDS150 I am testing came with.So the marine radio ( MHS338BT ) that uniden sells has the same footprint as the sds100 , but had a drop in charger with a battery pack. So I wonder if this is the battery the sds150 will be using .
I figured i would get on the speculation train. Woot woot
Doing some light necromancy, which fits the season.I participated in that thread. And no offense to Joe, but he was completely lost as to how preemptive priority on trunking is supposed to work. It works fine on 3600 systems, but who still uses those?
I know its not exact due to its size on the 150 but it similar. I was speculating .....I can confirm, that is not the battery the SDS150 I am testing came with.
