SDS150: New Uniden Scanner announcement at SEMA 2025
CollinsURG
Can you provide any specific frequencies that I can try?
Check out the Facebook page, "Florida Scanner Radio Group".
The activity is on discrete frequencies. Search 138-144 and 148-151 MHz. AM mode. 25 Khz channel spacing.
CollinsURG
FWIW I found this SDS150 Preview posted at AmateurRadioTransceivers.com (dated 11-07-2025). It contains a useful side-by-side comparison list of some of the new SDS150 features vs. the current SDS100 features.
The comparison does not say the SDS100 meets JIS4/IPX4 or any standard. According to Uniden, the SDS100 also meets JIS4/IPX4 standard, same as SDS150, which is rain/splashing water from any direction but not immersion. JIS3 would also be water resistant, but not from all directions, but the comparison only said weather resistant for SDS100. Seems to be no change there.
The rest of the side by side comparison seems to be correct from what has been learned so far.
CollinsURG
From where did they get the info "updated SDR platform" ? Would be interesting to know what have been updated in the SDR.
/Ubbe
Yeah, that wording was interesting, but there have been a few tidbits along the way that suggests an updated SDR platform. I am hoping they did the right thing not using a TV chip or at least not making it the RF front-end. There are a lot more SDR based receivers and tranceivers now than when the SDS100 was designed. There are probably a lot better SDR chips available, and probably not very expensive since they are much more widely used. Lots of new commercial and amateur radio gear that are SDRs.
CollinsURG
/Ubbe
It was in that side by side comparison in post 723. But without searching, seems I read something else that suggested a change to the SDR from SDS100. Given the major improvement in the NOAA weather channels reception something was changed. But I never reported improved SDR.
Ubbe
Stockholm, Sweden
Something must have changed when a comparison side by side shows a difference. But measuring the sensitivity of a SDS100 shows it has the same sensitivity as most scanners and more or less equal on all frequency bands. It's just its bad strong signal handling that affects reception in a real live RF situation. SDS100 uses a preamplifier to boost sensitivity. You can take a RTL-SDR dongle and pull up its gain to get the same sensitivity but the whole RF spectrum blows up with a huge amount of overload issues like intermod.
/Ubbe
flborror
There are already dealers who will accept scanner trade-ins and put the money towards your new equipment purchase. Main Trading Company and Zip Scanners are two vendors that currently accept trades. While these programs may seem easy and convenient to get some extra money for your new equipment purchase, you probably would do much better money-wise by selling your scanner here in the RR classifieds (probably the best choice) or on eBay, Craigslist or Facebook Marketplace.
As an example, Zip Scanners is currently offering only $300 for an SDS100 trade-in. If you follow that link, you will see that they also deduct $$$ if your scanner does not meet all of their listed criteria. You also have to pay the shipping charges to get the scanner to them for their evaluation and they will NOT pay any extra money for DMR, NXDN, ProVoice or Waterfall keys that are already installed.
From previous experience I would not do ANY business with Zip Scanners Just my opinion
CollinsURG
/Ubbe
Yep. Sensitivty is useless without good signal processing. Which is why I don't consider SDR dongles a serious option. They have a use, but since they have no real filtering or image rejection ability, I don't routinely use them. They are good for investigation, but can't replace a well designed receiver.
4436time
In Gov't We Trust
Colorado
With these new models, may a person request seeing a return of the -2sec delay and possibly adding a -15sec? Or a user defined setting?
Would also like to see more Custom service types added, for example, 25+, or more? There are numerous additional TG's/channels I would like to pick out of Business/Public Works, etc, but have run out of custom service types.
Also, reviewing this thread (2nd & 3rd posts) Getting started in MilAir - newbie questions and seeing the band search speed capabilities of SDR's, would it be possible to see something similar, say during the Search and Scan or within the Waterfall feature?
4436time
In Gov't We Trust
Colorado
Well, it's a personal preference, but I monitor encrypted TG's and sometimes it takes upwards of 5 seconds for some transmissions to end (not always silent) and it would be preferrable if the radio could actually be set to move on sooner. This value was removed with the HP line of radios.
Edit: I set all encrypted TG's to -5 second delay and would prefer -2 second delay.
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
What FW version and HP model was it removed in? I can only assume you are speaking on trunked systems which only have a TGID delay setting? Correct me in I'm wrong if the TGID you are monitoring is fully encrypted, I'd lock out that particular TGID, if it was partially encrypted you can set the TGID to -5 or -10 and it will skip the encrypted enable radios.
W1KNE
PITA from New England
New England
Hopefully the SDS150 brings back the option to avoid on replay, that seemingly stopped during one of the FW upgrades to the SDS 200.
(When replaying, you can hit "avoid" to make the scanner avoid the frequency you're hearing in replay. It's a great way if you missed the avoid button in time. The x36 series still does it fine)
Also another nice feature would be the ability to directly edit a channel. So if you hit the channel hold, you can press one or two buttons to edit it quickly without going through the nominal 6-7 menu steps to do so.
