Newark Airport Airspace > KPHL N90
rr60
I see the DB was recently updated I see to reflect the relocation of this sector from Woodbury to PHL Tower.
I have added the location of the transmitters. Generally unless you are within a few miles you will not hear the ground controller. All of these are not active all of the time. This depends on traffic volume and time of day and staffing. All of the data from the scopes is relayed to PHL. Plenty of news about this.🤷🏻‍♂️
Lastly often on the overnight 128.550 seems to handle the consolidation of N90 Sectors including approach, final and departure. These folks do a great job.
@k2hz made the submission apparently & @GTR8000 always on the DB.
Transmit
119.2EWREWR DepartureDeparture (Primary Departure)
128.55EWREWR Primary AppApproach (Primary Approach)
125.5EWREWR Final VectorFinal Vector Approach
120.15EWREWR North AppNorth Arrival Approach
125.625EWREWR 90 AppApproach (90-240 deg)
132.8SolbergEWR METRO AppMETRO Approach (241-269 deg)
127.6EWREWR MUGZY AppMUGZY Approach (270-330 deg)
132.7EWREWR 331 AppApproach (331-089 deg)
123.775SpartaEWR ZEEBO AppZEEBO Approach
126.7EWREWR Satellite AirportsSatellite Sector
353.75EWREWR Military UseMilitary Use
128.8EWREWR Departure 2Alternate Departure
120.85EWREWR Departure 3Alternate Departure
richee2000
Monitoring NYC from Sea Bright NJ, East Hanover NJ
are ALL of these now controlled out of PHL?
Transmit
GTR8000
NY/NJ Database Guy
BEE00
rr60
Yes the entire EWR Sector of N90 was relocated. I will not touch the third rail. Just search.
rr60
Post #6. It can’t get better than that. Bravo. No pun intended. @Ewr_atc
