dyrtjunkie
Would having two Larsen NMO150/450/800 Tri-band Antenna's on my trunk work better than one?
I have a BCT15 and am pretty new to scanning. I mainly want to track the PD (using the close call feature). I would have both antennas hooked up to the BCT15 (to try to get a clearer,not stronger, signal). Do you still think it would be a good idea?
Also, what do you think about the Low Profile Antennex (1in w by 3in h) antennas? Should i get one?
I'm not located anywhere near your area, but from the database it appears that CHP is primarily on 39-42MHz and I'd therefore question whether that antenna was going to optimize your ability to hear them. I'm not sure what will best cover the range from 39-800MHz.Well, not to hijack the thread, but what if you wanted to generally listen to 40 through 800 MHz using a BCT15 as you drive all around Northern Ca. Focusing primarily on CHP, Pol, Fire/EMS. And you already have a crappy glass mount. So you went ahead and optimized your programming to include only what you generally want to monitor. You feel you have done a good job getting the systems in that you want, but you still lack a good antenna. You now, based on reading threads in this forum as well as that "sticky" above decided that a Larsen NMO150/450/800 is your antenna. Is that the best possible antenna for this application, or would using two mounted as the OP originally asked an even better solution?
All I have is the supplied base extender antenna that came w the Uniden BCT15. I want to figure out I want to emulate what the PD has on their cruisers, which are three low profile antennas. Each are 1" wide and 3" tall and are NMO (New Motorola) mounted on the trunk. (I suppose one tuned for 150mhz, one for 450mhz and one for the 800mhz range) or at least that is what I am assuming. What is the best website to buy these low profile antennas? Or should I just buy the Larsen 150/450/800 and call it best results for the lease amount of trouble?
