dondraper40
Ok, uploaded several counties of data around Atlanta, GA using ScanCat and free files from Nat-Com.org into a Pro-95. It got the frequencies and ID's loaded but I could still not follow trunked groups (No VC - Voice Channel displayed) and low beep when pressing Trunk button.
Later, I discovered Win95 (much more usable and intuitive) and got the trunking working by changing the mode to MOT from FM next to all trunked frequencies (was this right?). Now some talk groups will display the numbers (or fleet-subfleet) numbers an I can "hold" on to a group on a trunked frequency! I was looking for a tall building to jump off of when this little bit of success changed my mind.
Most of the counties in the area appear to have trunked systems that have both Type I fleet/subfleet numbers and Type II GIDs. Is there anyway to use both of these in the same bank? If I set a Type I fleet map such as E1P1, then I get some XXX-XX numbers but none match what is programmed from Nat-Com. If I remove the fleet-map, then I get the 4 or 5 digit numbers and some match the text tag values but not all. Since the data files have a mixture of both, how I can get ALL of the Text tags on ALL groups/subfleets to display? Is there anyway to convert type I fleet numbers to the other format or vice-versa? Am I able to still hear all groups or subfleets regardless of how it is set?....and only the displayed numbers are changed?
Finally, does anyone have any Win95 files for the Atlanta area that are relatively accurate? And where is the most updated source for these values? The RR database looks pretty current but I still see numbers coming in on my scanner that displays numbers not in the trunked ID's listing for that county.
Any help would be greatly appreciated.
Don (dazed and confused)
