Snaxmuppet
- Joined
- Apr 18, 2024
- Messages
- 2
I am a total newbie. I am studying for my Foundation licence and have just got a Wouxun KG-UV9K HT.
I know this is only a 5W radio but I am some distance from my nearest repeater and I am not close enough to pick anything up. Eventually I will need to get some better kit with a good antenna setup if I am to use the repeater regularly but I wondered if there was anything I could do to improve the range of my HT first.
I am using the stock, dual-band antenna so I wondered if I could set up more of a base station antenna arrangement and connect my HT. Is that likely to give better results? If so then would it be significantly better to justify the effort/cost to do such a thing? If so, what would you suggest I do? The repeater is analogue voice only on 2M. But I also want to have a sensibly 70cm antenna too as there are local stations on 70cm that I would like to get. Is there a sensible dual-band antenna setup that would work or would I need a separate one for each band?
Any help appreciated.
BTW I live in Torpoint, Cornwall. Any suggestions for a club I might join where I can learn the ropes and meet up with other enthusiasts? There is one in Saltash but that is a bit of a drive.
