I use an LNA-1000 preamp on four of my five ST2 antennas. (and on a few other types as well)
On my home made X-Wing antenna I use an LNA-580 preamp which has a lower noise figure and doesn't cover 800 MHz.
This thread has links to the Monitoring Times article.
http://forums.radioreference.com/sa...8-mt-magazine-uhf-satcom-antenna-project.html
One of those ST2 antennas feeds 32 scanners including my Broadcastify.com feed.
Here:
http://www.broadcastify.com/listen/feed/381
By the way, that antenna was also the one I was using when I made the YouTube video in my previous link. So that was just one of the 32 outputs.
If you're in a strong RF area you could have problems with overload so it's best to have a variable attenuator in the line to adjust the level to where everything is clean and stable.
Alternately, you can use antenna splitters as 'fixed' attenuators.
A 2-way splitter has around 4 dB loss
A 3-way splitter has around 7-8 dB loss
A 4-way splitter has around 9-11 dB loss
Those numbers vary widely depending on manufacturer so you have to check the specs.
Rich
RF Bay, Inc
10-1000MHz Low Noise Amplifier, Model Number: LNA-1000 with SMA Female Connector. This unit is design for provide flat frequency response from 10 - 800MHz (-3dB at 1000MHz, usable to 1500MHz)
Frequency Range: 10-1000MHz;
Noise Figure: 2dB at 500MHz
Gain: 30dB at 1GHz
P1: 11dBm
IP3: +23dBm
DC Voltage: +9 to 15V
Full specs are here:
http://www.rfbayinc.com/upload/files/lna/lna-1000.pdf
Buy it here:
10 1000MHz Low Noise Amplifier LNA 1000 30dB Gain SMA | eBay
