Newcomer
BC1022
Hello. I am new to Ham Radios, and was wondering if there are any handheld radios that I can purchase that are not super expensive without first getting a license. I don't intend to broadcast, as I am aware there are many frequencies which I can face legal repercussions for transmitting on. I really only intend on communicating with friends or simply tuning into different frequencies.
AK9R
Staff member
Super Moderator
Central Indiana
In the U.S., the only radio services that don't require an individual license are FRS and MURS.
a727469
Maine
CB is still around. GMRS simple license and might be best. Both good for local communications. Or investigate in your area to find a HAM nearby to review details and help you determine if you might want to pursue an amateur license since the Tech class is not too hard.
You say you do not intend to broadcast but transmitting to a friend is broadcasting. There are many,many radios available once you determine what type of service you want to use.
You might want to take a few minutes and do a search in these forums for FRS, MURS, CB, GMRS. Many helpful posts.
spongella
N2HUN, Western NJ
I'll assume you're in the USA. If you are only listening, you can buy any radio you want. If you want to transmit without a license then ditto a727469 and AK9R.
FRS (Family Radio Service) radios are relatively inexpensive and easy to find on-line or even at some big box department stores or in sporting goods shops. Just don't place too much faith in the advertised ranges the manufacturer claims. Some 2 way FRS radios advertise a 3 mile range but this is under ideal conditions.
CB (Citizen's Band) radios generally have longer range than FRS radios but they'll cost more.
Hope this helps and have fun.
