NS9710
I have the Niagara Falls Fire Dispatch programmed as 460.575MHz, Narrowband FM [NFM], the tone is programmed as 151.4Hz, and a volume adjustment of +3, and I have tried EVERYTHING I can think of, even going to FM, and I have my volume set to 10, Squelch set to 2, which is my normal set [Vol & Sql], and for some reason the voice audio is just so quiet, even locked in for a bit and put volume to 15, still no difference, any suggestions?
All audio and telemetry on other bands are perfectly fine, it just seems to be this one conventional frequency, some TGRP or Conventional channels the audio is so prominent that I actually have to do a lower volume adjustment, for the life of me, I just can't understand why this one frequency is giving me such a fit.
Anyone with alternative ideas/suggestions how to counteract this low volume issue?
Firmware is up to date as is the database, so I know those aren't offset or improper set.
