If it was working a few weeks ago then it should still be -- as far as I know there have been no changes to the system in that time which would affect scanner settings. What are you receiving on 852.20625, voice comms or a control channel? If a control channel, does it show sysid B11E?
When you originally programmed the system, did you set it up as trunked? How did you stumble upon 852.20625? If the scanner was programmed properly a month ago and not changed then it shouldn't have ever come upon that frequency.
If you're hardly getting 860.7125 then see what you can do to improve that -- make sure the antenna is connected properly, try moving the scanner to a new location. You'll need to receive it with a fairly high decode percentage (say >70%) to trunk the system with any semblance of reliability. The Pro-97 only needs the four control channels programmed in, to program in any of the voice-only channels just slows it down and takes up memory unnecessarily.
