NJSP 6/21
rob8558
jerseycity, NJ
dont know why, but my uniden handheld was locking on a troop A control channel only....i deleted all of my troopA control channels then id scanned and was completely unable to lock on ANY control channels. so i put them back in and restarted the scanner and for some reason it doesnt lock on that troop A control channel rather it acts "normally" and finds troop B and parkway, pike control channels????
any ideas as to why the scanner would lock on only 1 distant control channel???
Joseph11
If you're in Jersey City, the North System, or the Troop B System, is the one you should be listening to. The South System, or the Troop A System, can't regularly be picked up in Jersey City.
bigreddawg76
As a side note, Joe, have you noticed that they seem to have been having problems on the Troop A & Troop C systems this week? I've heard a lot of "you were scratchy and unreadable" for the last week or so from both dispatch and road units.
W2SJW
Senior Member
Northwest NJ
They're in the middle of upgrading the microwave backbone in C and A right now. It's a sure bet that there will be hiccups now and then when you are dealing with such a huge system.
On the upshot, you'll be able to hear every TGID in the troop anywhere in the troop when it's all done...
elias1988
West Creek,NJ
Just heard 4-Comm dispatch talkgroup for Troop C, sounds fine it was scratchy before, is the upgrade done :?:
W2SJW
Senior Member
Northwest NJ
The upgrade is going to take quite some time. I'll ask my source about how far along they are...
RocketNJ
Pequannock, NJ
Untrue statement. With the NJSP switching to an Omnilink SmartZone system it gives them the ability to have talkgroups be statewide (NorthStar, SouthStar, etc). The The troop dispach talkgroups (Totowa, Netcong dispatch for example) will not be statewide.
And for the system to assign a channel for a statewide call there must be a unit on that system. If no unit is listening to that talkgroup in a system then the system will not assign a channel. That conserves resources. That's why it's called SmartZone.
RocketNJ
Pequannock, NJ
Troop C cutover to SmartZone operation is scheduled for tonight. Troop A in the fall.
There should be no improvement in RF signal strength after the cutover. The audio should be the same or better in simulcast overlap areas since they are upgrading the uW backbone and using GPS to control the system phasing. The new system provides more accurate phasing that the old system.
bigreddawg76
Thanks George! I live in an area where I can get Troops A & C at the same time so maybe I'll see an improvement!
Joseph11
I noticed that about every 1 second there would be a click or burst of static on each frequency, including one of the active two control channels. It was confusing my PRO-92, since it uses subaudible data to TrunkTrack Motorola systems. It stopped later yesterday, though.
elias1988
West Creek,NJ
So if Troop C is making the move to SmartZone tonight do i have to change anything with the talkgroups and system frequencies :?:
Joseph11
No. Unless any new talkgroups pop up or change, you'll be safe. BTW, the New Jersey State Police Central System uses a SpectraTAC system, don't they? If they do, will this change with the upgrades?
RocketNJ
Pequannock, NJ
I believe since the system is going to be digital capable they are switching to AstroTACs.
Joseph11
OK, good. That will eliminate that annoying beep at the end of a transmission.
W2SJW
Senior Member
Northwest NJ
George,
Thanks for correcting me on that. My only question is - will I now be able to hear the NJTP & GSP from one end of the troop to the other like I can now with Troop B? I've had to keep them out of my TGID lists because over 50% of the time, the transmissions are very poor. I can now hear every toll road transmission on the B system loud and clear since that upgrade was done...
RocketNJ
Pequannock, NJ
I think those talkgroups are capable of statewide. So, yes you might hear those talkgroups.
I'd suggest having three systems set up with each system containing talkgroups you want to listen to.
W2SJW
Senior Member
Northwest NJ
B and C have always been set up in totally seperate banks here in my 796 - I'll put the Holmdel & Cranbury TGID's and see how they sound...
