Njsp programming
Chesky
Is it compatible with the Motorola xtl series radio? Or is it p25 phase 2
wtp
Port Charlotte FL
System Name:New Jersey Interoperability Communications System (NJICS)
System Type:Project 25 Phase II
that means phase 2.
GTR8000
NY/NJ Database Guy
BEE00
that means phase 2.
FDMA or TDMA (or DDM if so equipped, which the NJICS is) is determined at the talkgroup level, not the system level. There are still a few dozen talkgroups on the NJICS that operate partially or primarily in FDMA mode on a daily basis due to older non-TDMA capable subscribers still in use. Despite the fact that the NJSP is almost exclusively TDMA, every now and again a NJSP talkgroup falls back to FDMA mode for a bit.
So aside from the point that blanket statements aren't helpful, the end result in this case specific to the NJSP talkgroup is that no, your old XTS/XTL eBay special isn't going to receive them for all intents and purposes. Unless you count 50 out of thousands of transmissions per month.
wtp
Port Charlotte FL
i looked the database over twice and did not find any phase 1, so i assumed he would not hear much.
and being in Florida, i would not hear any changeover.
so thanks Mr.8000
