Yaesu: FT-60
merlin
DN32su
What programming cables are compatible with the FT-60?
D31245
FN42
I use #3 below with the RT Systems Software (macOS version which is a breeze and never gave me any problems). They provide frequent updates to the software as well. I'll let others chime in for other options.
From ChatGPT:
The Yaesu FT-60R is a popular dual-band handheld transceiver, and it supports programming via a cable that connects the radio to a computer. Here are the compatible programming cables and relevant details:
Compatible Programming Cables for Yaesu FT-60
  1. Yaesu Original CT-91 + CT-29(or CT-27 combo)
    • The CT-91 is a mic adapter (3.5mm/2.5mm split) and must be used with CT-29 (RS-232 serial cable).
    • Hard to find and relatively expensive.
  2. USB Programming Cable (Third-party / Clone of CT-91+CT-29)
    • Most common and convenient solution.
    • Typically uses a USB-to-Serial chip, like:
      • FTDI (recommended for best compatibility)
      • CH340 (cheaper alternative)
      • Prolific PL2303 (can be problematic due to driver issues)
    • Ends in a 2-pin connector (3.5mm and 2.5mm) that plugs into the side of the radio.
  3. RT Systems USB-57B Cable
    • Officially supported and works with RT Systems Software (proprietary, but stable).
    • More expensive but reliable.
🔌 Connection Pinout (for DIY or Verifying)
  • 3.5mm (SPK) plug – Speaker (audio out)
  • 2.5mm (MIC) plug– Includes TXD/RXD for data/programming
    • GND
    • TXD
    • RXD
💻 Software Support
  • CHIRP(Free & Open Source)
    • Supports the FT-60
    • Works with most FTDI and CH340-based cables
  • RT Systems(Paid)
    • Requires their cable or specific driver match
    • Easier for beginners
🔧 Tips
  • Always install the correct USB driver for your chip (FTDI, CH340, or Prolific).
  • Avoid Prolific-based cables if possible — many cheap ones use counterfeit chips.
  • Use CHIRP with FTDI/CH340 cables for the most flexibility.
AK9R
Staff member
Super Moderator
Central Indiana
If you are going to use RT Systems software, buy their cable with the software: FT-60 Radio Programming Software | Yaesu Radio Software | Cloning Software
If you are using some other software, buy the Valley Enterprises or BlueMax46ers cable:
merlin
DN32su
Thanks people. I found the FTDI version CT-91. I have so many programming cables,just thinking not buyin somthething I already have.
I have a few with the single 3.5 mm plug, just puzzeled over the tip, two sleeves, and ground. None I have, have that plug, so buying yet another.
I really like RT systems, but awful expensive for a radio I am refurbing, Chirp, well, it works, but. Maybe some official cloning software.
TNX
From ChatGPT:
    • GND
    • TXD
    • RXD
💻 Software Support
  • RT Systems(Paid)
🔧 Tips
There is only one 3.5mm jack, used for speaker mics and programming cables.
Some Kenwood and Baofeng use 2 plug configuration. wont work for this Yaesu.
TNX
