Nmo mount size for car
Hi. I’m reinstalling my cb antenna. What nmo size do I use? 3:8 or 3/4? I don’t know the difference.
The difference is the size of the hole.
The 3/8" mounts require access from the underside of the roof. That can be useful in some applications.
The 3/4" mounts do not require access from the underside of the roof and are much easier to install in most applications.
Unless you have no headliner in your car, go with the 3/4" mounts.
Delivers1234
Modesto, CA
We one more thing. So I have a hood mounted cb antenna with the nmo lip mount. I used to have an nmo mount on the rear roof. Am I losing a lot of reception and transmission if it stays o. The good. The swr is 1.3 on the bearcat.IMG_3785.jpegIMG_3786.jpeg
I dunno. There is absolutely a drawback to mounting it off to one side like that.
While you'll never get a perfect ground plane on CB with any road legal vehicle, having it offset like that will make it slightly directional. Might be noticeable, might not. Putting it in the center of the roof will at least make it work equally well in all directions.
If it works where it is, and you are generally happy with it, leave it there. If you love to experiment and want to try your hand at installing your own, then move it onto the roof.
slowmover
Fort Worth
Tallest is what’s best. Longest antenna to fit 14’ clearance is maximization. (How I set up a big truck or my pickup). 5’ minimum length, as a rule of thumb.
Center of mass of metal (rooftop) isn’t just TX, it’s also RX. Unobstructed.
Distance
is the goal I use as a truck driver to try and stay informed of problems on the road. Lesser antennas + poor mounts + poor location goes against this.
Many warnings are faint. Thus, to meet the above goal it’s a matter of my radio system being best in overcoming the deficiencies of the radio systems of other men.
Hearing, and being heard, are worthy ends.
Citizen Band isn’t passive, it requires participation to get what’s promised.
To that, best radio (AM/SSB with NRC), makes both TX & RX “better” at both ends of conversations. Easier to understand others and for them to understand you.
— NRC-integrated just became available last year. Biggest change since intro of 40-channels. See:
Digital Signal Processing (NRC) is such that faint signals previously unheard can now be filtered and understood. My changing from 6’ to 7’antenna means not only can I hear that faint signal NRC made legible, now I can legibly hear the even fainter signal with whom he’s speaking given last bit of antenna height.
— What effort one puts forth will be repaid proportionately.
Antenna mount + location is the decision from which all other performance will descend. Get that right and do the rest as time, budget and desire allows.
In a sense it’s fairly quick to maximize what’s possible. Hard for me to see why stop short given risk while on the road. CB is the likeliest radio service to encounter all across the country.
And,
on the day one wants greatest distance on Sideband so ET can phone home to that family base station, . . is yet another incentive.
A SIRIO Performer 5000 on a Breedlove NMO mount is fair description of “best”. It’s what I gave my airline captain/ex-military flyer son, it’s what I now run on the big truck.
Read, research, ask questions.
Mobile Radio Installation Reference
