I'll be installing a NMO to a 3/16"-1/4" thick bracket mounted to my vehicle and wanted to know which NMO mount to use. Both sides of the NMO will be exposed to the elements as the bracket will be mounted externally. The hole through the bracket will be 3/8". I would like a good quality branded NMO mount and not a cheap off brand.
The other end of the cable will be connecting to my BCD436 Uniden scanner and this setup will be only used for receiving....no transmitting. Is a SMA Male connector placed on the end of the cable the best way to do this? Or is another end connecter preferred and then use an adapter to connect it to my 436?
Thank you for any recommendations for the NMO mount, cable, and connector.
