DSDPlus No audio through computer
ME343
ME/NH/VT DB Admin
Gorham, ME
I recently got a new computer. I set up my VBaudio cable and everything that I've used before and I'm not getting any audio to come through my speakers. I can use SdR trunk and get audio but not dsd+
bravo14
Polk County FL
What version are you using on DSDPlus? Try this
Click Output a box menu drops down look very top should have 1 or more selections click one
Click Control a box menu drops down click on Combined cc/vc
Screen Shot 03-30-21 at 09.52 AM 001.JPGScreen Shot 03-30-21 at 09.52 AM.JPG
GTR8000
NY/NJ Database Guy
BEE00
Assuming Windows 10, make sure that you've given permission for apps to use the "Microphone". Yes, this affects virtual audio cables on the input side as well.
Settings > Privacy > Microphone > Allow apps to access your microphone > ON
But yeah, 1.101 is 6 years old at this point. Many bugs have been fixed and features added. Frankly, no dbadmin should be running software that old, it can lead to the wrong data being decoded and making its way into the database. Please invest in Fast Lane ASAP.
ME343
ME/NH/VT DB Admin
Gorham, ME
Invested in fastlane. Got all set up still not getting any audio
ME343
ME/NH/VT DB Admin
Gorham, ME
Currently what I have set up. Is there something in the FMP24-CC or the 1R file that I need to set differently?
I'm using the default input and output for audio but can't hear anything. Could the TCP link be the issue?
GTR8000
NY/NJ Database Guy
BEE00
TCP linking is just the link between FMP24 (the dongle) and DSD+ (the decoding software). If you use direct linking, as you are, you don't have to worry about TCP linking. It looks like that's working just fine, otherwise you wouldn't even get any control channel decoding.
I would suggest on the Decoder menu, disable any protocols not in use, i.e. select only P25 for the time being to simplify things. On the Control menu, make sure Combined CC/VC Monitor is selected, as well as Voice/Data Call Following.
ME343
ME/NH/VT DB Admin
Gorham, ME
Well would that explain the no audio at all? It completely mutes my PC when I run FMP24 and 1R. Im monitoring the statewide system in Maine.
GTR8000
NY/NJ Database Guy
BEE00
"It completely mutes my PC" are you suggesting that merely running FMP24/DSD+ causes all audio output on your PC to mute? That's an odd one. And this is a new Windows 10 PC, correct?
ME343
ME/NH/VT DB Admin
Gorham, ME
Yes. Got it with in the last 2 months. and yes completely mutes like I can't even go on youtube or listen to the recorded audio and im not getting any audio from the decoded stuff at all even though im seeing it being decoded I can't hear it.
GTR8000
NY/NJ Database Guy
BEE00
I don't think I've ever run across that issue. Strange that even though everything is being muted, you're not even hearing audio output from DSD+. I could maybe understand if DSD+ grabbed exclusive control of the audio output so nothing else could use it, but that doesn't even seem to be the case here.
ME343
ME/NH/VT DB Admin
Gorham, ME
I disabled the VAC should i reenable that and see what happens
GTR8000
NY/NJ Database Guy
BEE00
Shouldn't matter at all, as the VB cable is no longer in play here. DSD+ is linked to the FMP24 tuner directly, and the resulting decoded P25 audio from DSD+ should be coming out of your speakers directly.
ME343
ME/NH/VT DB Admin
Gorham, ME
hmm. Ill have to mess with it more tomorrow. Im gonna try a single frequency dmr channel ans see if i get anything
ME343
ME/NH/VT DB Admin
Gorham, ME
So im able to hear it through head phones but not the speakers.
