There is, good.A good start to in seeking help is to post your op25 configuration files. IE: your rx.py command line or milti_rx.py JSON file.
Be sure to detail the hardware and Linux repo that you're using to run op25.
I did as indicated, -O or -O 0 or -O 1 or -O 2 or -O 3 and all gave the same return...You could try using "-O pulse" and that should direct the audio to the system's PulseAudio daemon rather than ALSA. If regular sound works ok this should too.
I decide to send the pictures when I open the HTTP. For further understanding. And still no audio.
Now with you explaining, I began to understand. Come on, I'm trying to receive the Police signal that was analogue and passed to P25 here in Brazil. And you see, here there is no information about these frequencies as in the USA. I tried with DSD+ and it didn't work because it's encrypted and it stays silent and doesn't open. Or I couldn't open it. I even sent this doubt here on the forum and they actually told me that it does not open.On the surface it doesn't look like you have an audio issue. I am not seeing any signs of op25 decoding Trunk Signaling Blocks (tsbks)
that should normally be incrementing when op25 is not following a call. The FFT (spectrum) plot doesn’t indicate any signal sitting at the
tuned frequency of 173.170 MHz. Are you sure you have the correct control channel frequency? What system are you trying to monitor?
Below are examples of what your FFT and Constellation plots should basically resemble.
View attachment 141208View attachment 141209
As I said it's the P25. " What system are you trying to receive, and what are the contents of your OP25SSP.tsv file?"As Bill observed, it really doesn't look like you are tuned to anything useful. Your screenshot "Plot.jpg" shows the tuning line resting firmly over dead-air and "Principal.jpg" shows no data received.
It may also be helpful to reduce the sample rate to "-S 1000000" as running an RTL at 2.5Mhz is right at or above the max range of it's abilities.
It's really partially encrypted, like: the base wants to talk to everyone or to a specific person, that's all. The rest like everything that could be active is not. From what I've been told.A couple of thoughts. It might be that your system isn't a Trunked Radio System (TRS) and would not therefore have a control channel
where you'd expect Trunk Signaling Blocks (tsbks) and might be P25 conventional. Moreover, if the system is fully encrypted, then there
is no point is trying to getting op25 running on it.
However, I would recommend that you run DSD+FL on whatever frequency that you've observed activity and allow it run long enought to gather data that can be used to better analyze what exactly the system is, and if indeed it's encrypted. Be sure to set the logging level to
-v4 that will provide greater detail about the communications protocols received.
About DSD + FL I have a file that I can send for evaluation. A TXT with part of this encryption. Thanks for the help on how I can hear again. I will make the change to log 4
Those are the images.OK, the logfile appears to be either a P25 Conventional or perhaps is one of the Traffic Channels associated with a Trunked Radio System.
If you don't have any hard data on the system then I would suggest using FMPx from DSD_FL to manually tune across the entire VHF spectrum to search for the presence of a control channel that would be transmitting continuously.
If you find a P25 Control Channel the FMPx spectrum window will appear similarly to the image shown below. If you should find what
appears as a control channel then clear your DSD+FL logs and capture a minute or so of data from this signal for further analysis.
I have attached the requested images above. In the post.On the surface it doesn't look like you have an audio issue. I am not seeing any signs of op25 decoding Trunk Signaling Blocks (tsbks)
Making some good progress now. Still appears to be Conventional P25 but the incoming signal level is overloading your SDR.New images.
