TRX-2: no audio
Pjjsarc
no audio thru speaker or headphones, re did sd card its scaning and stoping , ans squelch and volume working on display.
any ideas
tvengr
Well Known Member
Baltimore County, MD
If you still have the EZ Scan archive file you used to program it originally, copy the file to the scanner again to remove any changes you may have accidentally made from the keypad. Does it receive NOAA weather OK? What is the system you are trying to receive? They may have turned on encryption. If you attach your archive file, I can take a look at it. Click on Attach files and open the file.
